| Bad ground???; Speakers cut out | |
| Tweet Topic Started: Jul 27 2016, 08:10 AM (575 Views) | |
| Krajniak | Jul 27 2016, 08:10 AM Post #1 |
Krajniak
Ok guys and dolls here's my issue. Driving down the road minding my own when all of the sudden my rear speakers cut out and no more Barry mannilow Just kidding but seriously my speakers work one minute then they quit until I turn on a turn signal then they come back for a little bit the cut off again. I'm thinking maybe there is a grounding issue but not sure.Any advice or thoughts of your own? Thanks a million |
| Krajniak | Jul 27 2016, 02:10 PM Post #2 |
Krajniak
Noone else have issues ever? |
| evmetro | Jul 27 2016, 03:20 PM Post #3 |
I would look on both ends of the wire for which ever speaker is cutting out for wire connectionso that have been spliced and taped. If they are all cutting out, I would pull the deck and fix any connections that have been molested. |
| monzanut | Jul 27 2016, 03:27 PM Post #4 |
Drip under Pressure
Seen this post http://geometroforum.com/topic/5724454/1/ , do the speaker ground wires run to the fuse box too? |
| nineoneandblue | Jul 27 2016, 03:41 PM Post #5 |
Maybe your Geo is not a fan of Barry Mannilow..... Have you tried playing another artist? ..... Maybe some Led Zeppelin?
| Krajniak | Jul 27 2016, 03:57 PM Post #6 |
Krajniak
Ya some zepplin and acdc too but the cassette deck needs updated lol i agree im not a fan of barry either but it sounded good unlike my back speakers |
| Krajniak | Jul 27 2016, 04:03 PM Post #7 |
Krajniak
Ev its all factory i had the rear panels off when i bought it to insulate the rear walls and the deck is all original. Monzanut im not sure if its all grounded together i dont have a repair manual with the schematics ill have to look for one |
| monzanut | Jul 27 2016, 04:05 PM Post #8 |
Drip under Pressure
I have a FSM, can check it tonight when I get home if you want. |
| Krajniak | Jul 27 2016, 04:27 PM Post #9 |
Krajniak
That would be awesom if u have time if not ill survive and run all new wires when i upgrade to a cd player |
| t3ragtop | Jul 27 2016, 05:30 PM Post #10 |
speaker wiring does not share any connection to the car's electrical circuits except through the radio. the plus and minus speaker leads run directly from the radio's output transistors. if you even try to connect a speaker ground to chassis ground it will fry the radio. part of the protection of the radio is built right into the head unit. if you play the radio at high output when it is unduly hot, the thermal overload protection kicks in and mutes the output until it is reset. it might just be a condition of a hot summer and a weak factory radio.
| Krajniak | Jul 29 2016, 05:42 AM Post #11 |
Krajniak
Thanks t3 its just weird that they come back on with use of turn signals |
| Stubby79 | Aug 7 2016, 11:10 AM Post #12 |
Fronts still working? If you leave the indicators on, does the radio keep working indefinitely? |
| Krajniak | Aug 7 2016, 12:38 PM Post #13 |
Krajniak
Front still work correct, and no sometimes they stay on a minute then shut off, just thought it was crazy they come back on reliably when i hit a turn signal |
| Krajniak | Aug 7 2016, 01:24 PM Post #14 |
Krajniak
I have a spare aftermarket radio i may put in today and see if it's the radio |
7:56 PM Jul 10
