| 1.0L Head Repair Guide | |
| Topic Started: Sep 10 2008, 09:41 PM (6,637 Views) | |
| Johnny Mullet | Jan 19 2010, 10:51 PM Post #31 |
"Geo Whisperer"
I bought the Felpro head gasket kit at Auto Value parts store and the valves and head bolts came from 3Tech Performance. Under $200.00 for parts. You can find cheaper head gasket kits on Ebay for like $50.00 |
| StevieC | Jan 19 2010, 10:57 PM Post #32 |
Cool. Who do I contact at 3tech? I'm def gonna have to rebuild it at some point so I may as well do it when the van is up and running again! |
| Johnny Mullet | Jan 19 2010, 11:00 PM Post #33 |
"Geo Whisperer"
Just go to the page and E-mail Mike.............. http://geometroforum.com/pages/3Tech |
| StevieC | Jan 20 2010, 12:37 AM Post #34 |
Awesome, thanks! You should add this information to your guide
| damen1005 | Jan 28 2010, 04:50 PM Post #35 |
Where do I buy the valve spring compressor you have in your form ? Or any other type that will work ? I also need a magnetic valve keeper removal tool . damen1005 |
| starscream5000 | Jan 28 2010, 07:01 PM Post #36 |
AKA 95_G105spd
Just use a socket, put a socket over the valve spring that is the same or slightly smaller in diameter, put a shop rag over the top of it, grab and hammer, and give it one good HARD wack. Done. To reinstall, place the keepers in position, place the socket over the valve, and press down manually HARD, they should fall right in place. This method worked for me. |
| Johnny Mullet | Jan 28 2010, 08:57 PM Post #37 |
"Geo Whisperer"
Read it here........... http://geometroforum.com/topic/1299263/ You can see it illustrated. |
| gasmizer | Feb 24 2010, 10:36 PM Post #38 |
I use your guide to replace the head gasket on my 1993. Great info. Thanks again. |
| new_kid | Aug 10 2010, 05:39 PM Post #39 |
Are the head bolts to be replaced as I understand on later model as on the 89-92 3-bangers when rebuilding the cylinder head? |
| Coche Blanco | Aug 10 2010, 05:45 PM Post #40 |
is soon to be "Shaggin in the Wagon"
Are you asking do you replace the head bolts? Yes, you do. |
| Johnny Mullet | Aug 10 2010, 08:51 PM Post #41 |
"Geo Whisperer"
Always a good idea! |
| bogs | Aug 11 2010, 03:21 AM Post #42 |
Unless they came from 3tech. |
| new_kid | Aug 11 2010, 12:40 PM Post #43 |
Ok, understood, thanks. Just curious....what is likely to happen if this is not done?
| Coche Blanco | Aug 11 2010, 01:27 PM Post #44 |
Snap when you re torque them. |
| Bad Bent | Aug 11 2010, 07:10 PM Post #45 |
Some sort of "universe ending paradox" could happen.
| « Previous Topic · Guides/How to · Next Topic » |
1:37 PM Sep 3
