XFI Cam Installed Today; Finally put it in...
Topic Started: Oct 21 2008, 06:39 PM (1,276 Views)
kimmer6
Finally, after getting my reground XFI cam I decided to put in my newest Metro convertible. From start to finish it was a 3 hour job. Of course, I have all of the tools, the cam was sitting there collecting dust for 2 months, and finally I got the willpower to get 'er done. Basically I had to take the distributor off, pull the valve cover, take the water pump pulley, belt, and the crank pulley off, then remove the plastic timing cover. I had the crank at zero degrees TDC on #1, the cam wheel marks lined up, and I added some special markings in case I went brain dead and had to put the belt on without screwing up.
It went in with no bother. I used Redline assembly lube on the lobes and the 3 cam bearings. While I was at it, I put in my 8 degree advanced cam wheel, lined everything back up and turned the engine over a few times by hand. I also marked the distributor and backed it off 8 degrees to run at the same timing I had before.
In case anyone EVER forgets which way a Metro engine turns....just remember it goes the same way as the wheels.
It started right up, ran fine, and I took it for a ride to get some Synthetic Automatic Transmission Fluid to drain and refill the 5 speed transaxle. It takes 2 quarts. The increased torque and polite low rpm response was immediate. This cam is a must for a short shifter like me. It pulls from 1200 rpm without much fuss. I can't wait to get the mileage numbers! For grins I will order some headbolts and head gasket and try grinding Singh grooves in the head. It promotes swirling and can only help in getting better mpg.
I got the cam from Delta Camsaft...1938 Tacoma Ave. South, Tacoma, Washington 98402 Their Number is (253) 572-2474
I think it was $70. I sent in an old cam for a core and got back a nice looking one with XFI marked by the cam sprocket face.
This was the easiest cam change I ever did! Whoever wants to do it and is scared....I'll be glad to help. ....Kim
Thank you for the assurance that this job is still easy even after being in there once. I actually have an extra cam in my garage I got from Metroshultz. I want to get an XFi grind, but lately my wife has been driving and she really winds the car out :nfs
I keep telling her about it, but gave up. I am now leaning more into putting a performance cam in the Metro for her sake and find another Metro for myself :)
x guy
Which rated auto trans fluid do you use for the metro 5 speed?
Is this as good as Redline MTL?
Thx
99metro
putt-putt
My 8* and "economy" cam from 3Tech still sit in a box. My current JDM has the older pre-96 wheels, and the 8* is the 96-up wheel. Once I want to tackle getting the crank pulley/gear off again, I'll swap all the wheels/components and get them installed. Maybe my winter project?
x guy
Oct 21 2008, 09:21 PM
In the Automatic Metro slush-box, just use Dexron/Mercon fluid like any other GM.
Welcome to the board :thumb
Hacksaw
Disciple of Johnny Mullet
I think the question was meant to mean, "which auto tranny fluid can be put into a 5-speed?"...
I have read a people doing it, but I'll just stick with Pennzoil Syncromesh...
Hacksaw.
