| Clunk under load while turning | |
| Tweet Topic Started: Sep 1 2016, 11:03 AM (345 Views) | |
| anytimeminutes | Sep 1 2016, 11:03 AM Post #1 |
Not much more to it than that. When I say, "under load", I mean when I hit a bump or a dip. I've had the noise for about a month, just today I jacked up the car and almost nothing has play in it. Except the drivers tire jiggles up/down and left and right. Which I assume is a hub. |
| monzanut | Sep 1 2016, 11:27 AM Post #2 |
Drip under Pressure
if its that loose, bearings are probably wasted. |
| snowfish | Sep 1 2016, 11:28 AM Post #3 |
First need to isolate where the jiggle is coming from. While jiggling the tire at 12 o'clock & 6 o'clock positions, movement could mean bearings or ball joint for the front. For the rear, either bearings or other suspension components. While jiggling the tire at 3 o'clock & 9 o'clock positions, movement is possibly the tie rod ends for the front. For the rear, either bearings or other suspension components. All of these will make a clunk at one time or another. ![]() A bad bearing will growl when spinning the elevated wheel.
| Bjetmech | Sep 1 2016, 11:59 AM Post #4 |
You could do all the above and have someone lay on their back and look at these areas to see what is moving. If your hearing a noise you should be able to see movement too. |
7:30 PM Jul 10
