Excessive vibration 94' automatic Geo Metro; I've got a LOT of vibration in the cabin of my 94' automatic metro
Topic Started: Nov 12 2016, 09:20 PM (289 Views)
19isaac97
Isaac
Hi, I got a LOT of vibration in the cabin of my 94' automatic metro, I changed the 3 engine mounts (right side, firewall and one that is located below, put a pic of it)
What could be the root cause of the excessive vibration?
I've disabled the AC compresor, I discarded the axles, wheel brearings..mainly because the vibration occurs when the car isn't in movement too, so...I guess is something related the transmission, because the vibration increases when I accelerate in "L", "2" or "D" (at slow speed)
I also checked one mount that is located right under the battery, but it is ok, what else can I do? Plugs, plugs wires, rotor and distributor cap are ok..
Edited by 19isaac97, Nov 12 2016, 09:21 PM.
Have you run a compression test? Perhaps you have a low cylinder.
