| front tire feels like its falling off on hard left turn; tire/wheel skipping | |
| Tweet Topic Started: Nov 14 2016, 03:14 PM (515 Views) | |
| finewood1080 | Nov 14 2016, 03:14 PM Post #1 |
91 geo metro 2door hatch 1 ltr. 5 speed This is the biggest headache I have had to deal with on a Metro. When I turn right (only) the front end shakes violently and pushes to the left in the curve. this is what I have done so far: Replaced Rack & pinion Inner and outer tie rods Tires and wheels Wheel bearings and housing Hubs lower swing arms 4 wheel alignment (twice) The horns are in great shape (no rust) I need help what else could it be???????????? |
| David95237 | Nov 14 2016, 03:26 PM Post #2 |
If you have been through all that and your alignment guy couldn't find any thing wrong, Its haunted. Better due an exorcism. |
| WiscoMetro | Nov 14 2016, 03:30 PM Post #3 |
Seeking the Science of MPG
Liter is abbreviated just L, not ltr Only thing I can think of is does it happen if you make the turn in neutral, because it sounds like your passenger cv doesn't slow down to correctly make the turn. |
| CAMI MAN | Nov 14 2016, 05:25 PM Post #4 |
I know you said the frame horns are good . I would check your frame horns again
| Scoobs | Nov 14 2016, 10:08 PM Post #5 |
I see nothing about struts, springs, or strut mounts. |
| finewood1080 | Nov 15 2016, 10:15 PM Post #6 |
made several hard turns with clutch depressed and in neutral no difference. the shimmy is still there. |
| finewood1080 | Nov 18 2016, 09:36 PM Post #7 |
Yes I have rechecked the frame horns. No damage or rust Ps. thats one clean metro you have there |
| finewood1080 | Nov 18 2016, 09:39 PM Post #8 |
Sorry! I do not know if it is a (GEO) or Suzuki. |
| finewood1080 | Nov 18 2016, 10:00 PM Post #9 |
Replacing the drivers side front shock has helped considerably,It has not removed the shimmy completely but has made it better, to the point I can wait to buy new shocks this is a used shock out of a donor car. Rockauto.com has the lowest prices I have found yet at $145.00 set of four KYB Excel. Thanks for everyone's input.... |
| sphenicie | Nov 20 2016, 07:57 AM Post #10 |
DITTO ! no body wants to find rusted horns, denial, denial, denial. |
7:30 PM Jul 10
