| gaskets / home made vs. factory store; tips | |
| Tweet Topic Started: Nov 22 2016, 03:01 AM (201 Views) | |
| ice | Nov 22 2016, 03:01 AM Post #1 |
alex smiles
Well I found the vacuum leak on tbi . The "right" gasket just did not cover it well enough . I got a roll of gasket maker .And I cut out the gasket a tiny bit bigger.And I only cut the holes that the trottle body needed. the gaskets from the store have a bunch of extra cut outs . hope this helps someone |
| ptcapboy | Nov 22 2016, 06:42 AM Post #2 |
do you still have your watercolors from when you were a kid ice? if so you can paint the bottom of your TB-place it on the gasket material-viola instant gasket pattern- |
| Car Nut | Nov 22 2016, 07:47 AM Post #3 |
Great idea!
| sphenicie | Nov 22 2016, 08:01 AM Post #4 |
there are several different types of gasket mat. Just like preformed gaskets, as well as 'gasket goop', some react to fuel/oil others do not. Some handle heat better and some do not. Be sure to use the correct type. |
| freegeo | Nov 22 2016, 11:29 AM Post #5 |
Do you happen to still have the gasket with too many holes? Would be interesting to see what created the vacuum leak. Could you post a picture of it? |
| ice | Nov 22 2016, 03:37 PM Post #6 |
alex smiles
hi free , will do . but with that leak found . i passed smog with flying colors :)) |
9:33 AM Jul 11
