Fuel pump
Topic Started: Nov 24 2016, 12:41 PM (186 Views)
Geo05
I have a 94 geo metro automatic hatchback base vin 2c1mr6461r6765227 what would be the right fuel pump to order the engine turned over a little before it was barley running and the injector looks brade new.
freegeo
Wouldn't you rather check some components out and do some test before just buying parts that may not fix it? If you suspect the fuel pump is out check the fuel pressure 1st. Could be be wiring, relay, fuse, fuel pump or injector. Thats even if it is fuel related causing the not start.
freegeo
If you want to check out the fuel system. Use the link below. Look in section 6E2-A1 ENGINE COMPONENTS WIRING DIAGRAMS DIAGNOSTIC CHARTS. It starts on page 22.
Since you have a 94 check and see if you have standard emissions or upgraded. There can be some differences in how it is tested.
http://geometroforum.com/topic/5044844/1/#new
