| Crank no start; 1994 Geo Metro 4-door hatchback 1 liter automatic transmission | |
| Tweet Topic Started: Dec 2 2016, 10:22 PM (181 Views) | |
| Geo05 | Dec 2 2016, 10:22 PM Post #1 |
I pulled off the fuel line on the top and gas was coming out a lot and seemed like it would not stop. The fuel injector has one broken screw and is held on by one screw. I replaced the tps sensor and installed a remanufactured injector. The EGR valve is only two years old. One day I was filling up the tank and parked a few miles somewhere else then gas was coming out of the fuel cap when the cap was closed. Last time I drove it was idling really rough then last time I trid to start it turned over then was idling extremely rough then died when I give it Full Throttle. The starter is about 6 months old and seems like it has a hard time turning over the engine. Then I gotta keep on playing with the ignition switch to get the starter to turn. And now the starter seems like it's not grabbing on to the transmission flywheel like it's skipping teeth. The timing belt is still on and is not broken.
Edited by Geo05, Dec 2 2016, 10:27 PM.
| freegeo | Dec 3 2016, 04:20 AM Post #2 |
You need to fix this problem so you will be able to figure out the rest of the problems. Is the starter possible loose? You may need to take it off and get it check. |
9:29 AM Jul 11
