| 8v vs 16v piston valve relief question | |
| Tweet Topic Started: Dec 3 2016, 01:40 PM (265 Views) | |
| suzukitom | Dec 3 2016, 01:40 PM Post #1 |
Tom
Quick question for g13ba and g13bb engine experts: Can you swap a G13BB 16v SOHC head onto a G13BA 8V SOHC short block? The valve relief into the tops of the pistons is obviously different. . Just wanted to know if this is a critical difference on a stock motor. Thanks! Edited by suzukitom, Dec 3 2016, 01:40 PM.
| MarkZ28 | Dec 3 2016, 11:00 PM Post #2 |
I bet it wouldnt be a non interference engine if the belt broke at the least. |
| suzukitom | Dec 4 2016, 12:44 AM Post #3 |
Tom
Thanks Mark. You're right.. the non interference feature must rely on matched pistons for each head configuration. I was curious whether a stock g13ba 8v short block would (with an intact timing belt) run normally with the 'wrong' sohc 16v head attached to it. |
| Hotrodray1 | Dec 4 2016, 03:12 AM Post #4 |
Over Educated parts guy
Yes it will run good but as you say if the belt brakes you are in trouble. I did this to a 98 4dr about 3 years ago and it ran great! At the time that 8 valve short block was all the owner could find. His his 16 valve short block was not repairable big hole in side of block. |
| MarkZ28 | Dec 4 2016, 03:06 PM Post #5 |
Would compression be changed much? |
| Hotrodray1 | Dec 4 2016, 03:22 PM Post #6 |
I checked it was 180 psi per cylinder after I did it. |
9:29 AM Jul 11
