| sputters occasionally; Sputter while driving | |
| Tweet Topic Started: Dec 3 2016, 03:09 PM (236 Views) | |
| skydivemark | Dec 3 2016, 03:09 PM Post #1 |
'95 metro, 3cyl, 1L, 316,000 miles (Yes, it's the original engine, never rebuilt except for replacing exhaust valves at about 110,000 miles). Once in a while it will start sputtering while driving. If I shut it off and re-start it, it runs fine. About 8 months ago when first starting it would idle very high (2200-2500rpm or more) while raining or high humidity(fog) and once it warmed up and I re-start the engine it would return to normal, maybe even idle a little low. A couple weeks ago I was driving at about 60mph and it started sputtering and loosing power. I pulled to the shoulder and continued to slow down, eventually it quit running. When I re-started it, it ran fine. The che k engine light came on a few days ago and is code 23 (MAT). Parts stores (local and online) don't show a m.a.t. for that year/model. A few months ago it had code 51, EGR, but I found the cause and it hasn't returned. |
| ptcapboy | Dec 3 2016, 04:55 PM Post #2 |
napa MPE TS6677SB should do it- |
| freegeo | Dec 3 2016, 07:28 PM Post #3 |
Code 23 is for the intake air temperature sensor. |
| skydivemark | Dec 4 2016, 08:19 AM Post #4 |
Did some more checking and found the problem with the IAT. Check engine Light is out. Will update if I get more sputtering. |
9:29 AM Jul 11
