| more power; bigger fuel injector | |
| Tweet Topic Started: Dec 4 2016, 11:42 PM (567 Views) | |
| tazome | Dec 4 2016, 11:42 PM Post #1 |
I had my fuel injector rebuilt along with the engine , i had it enlarged to having a higher fuel flow rate over the factory an what a differance it makes, but i dont recomend it if your running a stock tired engine . dr injector of sacramento ca did the modifcation if interested . gas mileage is 27 to 40 highway but its better than a new car |
| freegeo | Dec 4 2016, 11:56 PM Post #2 |
Are you running the stock ECM? Just rebuilding a engine alone and getting the clearances right can make a big difference. |
| LesCrapp | Dec 5 2016, 12:41 AM Post #3 |
Legend
LoL! the gurus will be here to explain this one again I'm sure... |
| myredvert | Dec 5 2016, 09:57 AM Post #4 |
I would love it if someone would explain how the ECM was convinced to reduce the scheduled fuel as necessary to maintain stoich while in Closed Loop operation, or how you can get more power than the best power air:fuel ratio, which is roughly what the ECM schedules fuel for while out of closed loop and in the power enrichment mode? And where is the additional intake airflow coming from to mix with all this fuel in order to turn it into more power?
| snowfish | Dec 5 2016, 11:18 AM Post #5 |
I think he means had the throttle body bored like here. http://maxbore.com/index.html ![]() ![]() Works very well on snowmobiles, ATV's, PWC's, etc. My buddies 1000cc ProStock SkiDoo has bored throttle bodies. 148+mph in 1000ft. Even on the 600cc Improved class sled, running the stock ECU, very noticeable gains have been achieved. If it works for those, why not our Metro's? I have considered this myself for my next refresh. I have until March to make the decision. |
| freegeo | Dec 5 2016, 11:35 AM Post #6 |
Does the snowmobile have a O2 sensor? |
| snowfish | Dec 5 2016, 11:48 AM Post #7 |
Yes. However many current flashes have deleted the O2. Like the 2017 Yamaha Viper and Sidewinder. Straight mapping, no 02 sensor. Not sure how that works. Just know it does. You're thinking our Metro's O2 sensor will negate any gains that boring the TBI would do?
Edited by snowfish, Dec 5 2016, 06:30 PM.
| cwatkin | Dec 5 2016, 06:34 PM Post #8 |
I don't fully understand the "straight mapping" but suspect it is a pre-programmed input based on the throttle position sensor, etc. to simulate a carburetor. I suspect this would be a tad rich to be conservative and not run the thing lean. I suspect that is very important on these cars with their tendency to toast exhaust valves. I know there are some turbo mods for these cars and would suspect something similar must be done to accomodate the turbo. How is that done? I suspect it would be similar. Conor |
| nineoneandblue | Dec 5 2016, 06:45 PM Post #9 |
With one of these of course!........ http://www.ebay.com/itm/like/182372500485?lpid=82&chn=ps&ul_noapp=true
| freegeo | Dec 5 2016, 07:27 PM Post #10 |
Lol! Myredvert will love that. |
| freegeo | Dec 5 2016, 07:32 PM Post #11 |
The O2 sensor does nothing but send a signal to the ecm/pcm. The ecm/pcm does the adjusting of the AFR with stft as long as it is in closed loop. The ecm/pcm can't adjust air only fuel. |
| LesCrapp | Dec 6 2016, 01:56 AM Post #12 |
Legend
Look up Speed density vs. Mass airflow... |
| snowfish | Dec 6 2016, 08:59 AM Post #13 |
Straight mapping was a poor term. Without going too far down this bunny trail, the latest ecu program, and re-flash for 2014 to current 1049cc Yamaha sleds, has eliminated the O2 sensor. BUT still incorporates all of the other sensors including EGT exhaust gas temperature, and AFR air fuel ratio sensors on the factory turbo models. Someone way smarter than me figured all this out.
Thanks FreeGeo.
Good stuff Lescrapp. Going to take awhile to dig through what comes up in the search. Still looking. or do you have a favorite link? Hopefully Tazome will come back soon. Hasn't been around since the original post.
| LesCrapp | Dec 6 2016, 10:13 AM Post #14 |
Legend
LoL! Yep but I learn something every time I do that search...
9:29 AM Jul 11
