Amp install; Can you bridge a four channel amp
Topic Started: Dec 5 2016, 11:48 PM (314 Views)
92convertable
I have a 8" sub in a tube and a 400 watt four channel amp can I bridge the amp so all the output goes to one speaker? If so how do I wire the amp? If not will running all four channels to the speaker make it any louder or am I just wasting my time trying. if its a lost cause I will use this amp for my high and midrange speaker's
Bjetmech
If you pull up the specs of the amp and it reads like below, yes
225W RMS X 4 @ 4 OHMS
450W MAX X 4 @ 2 OHMS
900W MAX X 2 @ 4 OHMS BRIDGED
92convertable
Thanks just going to use the four channel to run high and mids
maxima2fst4u
NOOB
depends on which amp you currently have as well! Some can be some cant.
