| I think my belt squeal is back | |
| Tweet Topic Started: Dec 11 2016, 07:50 PM (358 Views) | |
| clen | Dec 11 2016, 07:50 PM Post #1 |
Buy 'Em Up! Now!
So I had all my belts done and this is the first day of snow. I drove all day but when it anowed, I started to get a squeal when I accelerated. It would happen and then go away. Could it be the belts again. I just had all of them replaced |
| MPG | Dec 11 2016, 10:37 PM Post #2 |
Sounds like a good tightening up is needed, new belts will naturally stretch with normal wear I had a belt squeak in my 91 , lossened the mounting bolts on the alternator and wedged a pc of wood in and pried the alternator back (the alternator acts as a tightner) and retightened the mounting bolts and squeak free since |
| clen | Dec 12 2016, 11:14 AM Post #3 |
Buy 'Em Up! Now!
I got the belts done two weeks ago and I put 74miles since. I really only use my car on the weekends. |
| Metromightymouse | Dec 12 2016, 10:09 PM Post #4 |
If you had someone who isn't intimately familiar with Metros replace the belts I can guarantee they didn't get the alternator belt tight enough. |
| ptcapboy | Dec 13 2016, 01:03 AM Post #5 |
would you have to replace them? couldn't you just tighten them some more? thrifty minds wanna know- |
| Crvett69 | Dec 13 2016, 01:10 AM Post #6 |
unless they have cracks from overheating from the belt slipping and making noise just tighten it more |
| Stubby79 | Dec 13 2016, 05:53 AM Post #7 |
Tighten it. Or drive it more often. If it's going to squeal, it's going to do it after a longer period of rest. Mine will give a short squeal after having sat unused for a couple of weeks; it will probably be worse in cold weather. |
| Woodie | Dec 13 2016, 06:50 AM Post #8 |
Normal people can't comprehend how tight it needs to be, doesn't seem right. Also, new belts stretch a little. I had a new belt put on by the dealer way back in the day (it was February and I didn't feel like screwing with it) and had to take it back for re-tightening three days later. |
| Car Nut | Dec 13 2016, 10:25 AM Post #9 |
With any other car, you'd think you were going to fry the alternator bearings, by tightening it the same amount. Tighten the piss out of it. When you can play a tune on the belt, it's good.
| clen | Dec 13 2016, 10:49 AM Post #10 |
Buy 'Em Up! Now!
Thank you all. I think I'm going to drive it a bit more and then bring it in to have them tighten them again. |
| Dystopiate666 | Dec 13 2016, 04:57 PM Post #11 |
Tree Banger
Mention the pry bar between the block and alternator to the service writer. |
| MPG | Dec 13 2016, 08:03 PM Post #12 |
Tighten it like your life depends on it 😏 |
9:29 AM Jul 11
