Engine Code 51 - EGR System & REGT Sensor Circuit
Topic Started: Dec 13 2016, 07:42 PM (355 Views)
Hydrojim
My 94 3 cylinder is throwing the following code
51 - EGR System & Recirculated Exhaust Gas Temperature Sensor Circuit
Any suggestions or ideas of what I'm looking for? I'm thinking this weekend I'll start pulling things apart and cleaning out EGR passages.
ptcapboy
that would be a great start-I would remove the egr valve and clean the 2 passages within it and make sure the plunger move in and out-then I would clean the passage from the valve to head and from the valve to the TB before re-installing the valve-finally I would disconnect the exhaust manifold from the head and clean the passage in the head and the small passage in the exhaust manifold-also check your vacume lines and where they connect on the transducer or whatever it's called
sphenicie
if you have a 6" piece of 1/4" cable, you can chuck it in a drill to get in there. run it forward and in reverse, as the cable freys it will polish the ports. hold the vacuum there close to collect all the carbon.
