| rebuilt engine; runs/starts issue | |
| Tweet Topic Started: Dec 15 2016, 03:35 PM (242 Views) | |
| fumes99 | Dec 15 2016, 03:35 PM Post #1 |
Replaced my chevy metro automatic 1999 1.3L rebuilt 2 weeks ago 0 miles. when you start it up 1st time it runs great purrs like a kitten but here is the problem. once you shut it down it will not start up again . come back the next morning starts then won't start pain in the A what could be the problem |
| freegeo | Dec 15 2016, 05:05 PM Post #2 |
When it won't start back up. Check for spark at the plugs, fuel coming out of the injector and compression. Find out which one you don't have |
| fumes99 | Dec 15 2016, 05:28 PM Post #3 |
We have checked all that 2 and three times any suggestions where to get a non bias opinion in the Chicago area. Thanks for your input |
| fumes99 | Dec 15 2016, 05:34 PM Post #4 |
By the way have owned 6 of these babies since my first one in 1991 .Frames have rusted before the engine died. Love my metros still have one other 99 1.0L just replaced the engine 5 months ago and no problem. |
| freegeo | Dec 15 2016, 07:21 PM Post #5 |
You have all 3 of those things and it won't start? |
| Woodie | Dec 16 2016, 06:40 AM Post #6 |
If it were a three cylinder I'd say your fuel injector is stuck open, flooding the engine. Your car has four injectors, unlikely that all four are leaking, one or two should be close enough to right that it should start. Maybe the coolant temperature sensor (or wiring) is bad and the computer thinks the engine is really cold. When it is really cold that's fine, but when it's not it's getting way too much fuel. Do you have a Check Engine light on? Maybe the fuel pressure regulator is stuck closed and it's getting too much pressure. |
9:28 AM Jul 11
