| oil INSIDE distributor | |
| Tweet Topic Started: Dec 21 2016, 02:53 PM (253 Views) | |
| bluestone | Dec 21 2016, 02:53 PM Post #1 |
My 92 Geo 5spd manual 1.0 had problems, even after warming up, with smooth idling, acceleration and power and there was a clattering sound around 45 miles per hour. So, I replaced the spark plugs and spark plug wires, thinking that they may have been the source of the problem, then I replaced the distributor but the problem remains. Upon closer examination, there is oil at the bottom, INSIDE the distributor. Initially, I thought that it may have come from oil leaking out from either the distributor housing gasket and/or the o-ring. That oil is visible on the block. My question is: Does this oil inside the distributor require that I replace the distributor or will the gasket and o-ring typically solve the problem? Thank you for your attention.
| Stiffchezze | Dec 21 2016, 04:09 PM Post #2 |
Sir Metrologist
Internal seal. There are a couple of guys on the forum that rebuild them for a couple of bucks, or you can replace it yourself. The part number is not listed at the part store, but it is listed here on the forum..... I think in the oring thread.
9:28 AM Jul 11
