Head warp tolerance?
Topic Started: Dec 27 2016, 11:53 AM (309 Views)
Krajniak
Krajniak
Ok guys I have looked in the manual and cannot find the tolerances. I have my head off because the head gasket went bad after not properly torquing the head down after ring replacement. What I am wondering is the Tolerance on head warpage I know there should be none ideally but nothing is perfect any help would be appreciated guys thanks
Krajniak
Krajniak
Sorry guys it's on my 93 Metro 1.0 liter
freegeo
Check the link below. It is for the 94 FSM. Look in section 06A1 ENGINE MECHANICAL 1 LITER L3 VIN CODE 6026, page 30. I can only remember seeing a tolerance for checking the head not the block. I would use the same tolerance.
Looks like the tolerance is .002"
http://geometroforum.com/topic/5044844/1/#new
Edited by freegeo, Dec 27 2016, 12:10 PM.
Krajniak
Krajniak
Thank u very much freegeo
Krajniak
Krajniak
Within tolerance i cant get a .002 feeler in there so im going back together. Hope to hear her purr in a few hours
In addition to the reference that freegeo posted that gives tolerances for the cylinder head mating surface, the 1991 Factory service Manual specifies tolerances for the cylinder block gasket surface.
1991 FSM 6A1-45
Flatness
Standard .0012"
Limit .0024"
Krajniak
Krajniak
Thanks redvert and freegeo i have her back together and she runs right on down the road.
