connecting rod B2?
Topic Started: Dec 31 2016, 02:35 PM (194 Views)
geometromaniac
I am putting new rings and rod bearings in my Metro. The first piston is out. The connecting rod has a number stamped in it by the bearing cap it says B2. Does that mean anything I should be concerned about? The car only has 80,000 miles on it. I was going to put clevite standard rod bearing in it.
freegeo
geometromaniac
Not sure where you are seeing the B2. There are numbers on top of the cap and down the connecting rod.
Do the bearings look bad. Some of the after market bearings tend to be thinner than originals ones.
