Engine Surges!!!!????; Engine surge?
Topic Started: Jan 3 2017, 12:09 PM (197 Views)
Tom's Geo
I have a 1993 Geo Metro 3 cylinder 5 speed G10 just rebuilt. It turned over first crank, I was so excited to see that happen. I hear that its rare for that to happen. Anyways, after the computer acclimated to the new air and fuel ratios. My engine stayed at a high rpm and started surging so I turned it off. When I turned it off it took a little more time stop running too. I don't know what it could be. I have diagnosed all parts of throttle body and iac and hoses no vacuum leaks anywhere all line were changed in the rebuild and routed to the right areas. I have replaced the tps censor with a used one and it started to have a smaller interval of surging. Any ideas on what the issue could be?
freegeo
When you replaced the tps did you adjust it to the correct voltage value according to the FSM?
Edited by freegeo, Jan 3 2017, 01:57 PM.
