Fuel sending motor in tank; Fuel sending motor in tank
Topic Started: Jan 3 2017, 02:28 PM (210 Views)
ddave
Ok. Not bad gas. 94 with sending motor in tank. Test. Pull bottom line
On filter. Turn key. Motor whirls. No gas coming out of line. Is this normal?
Is there a free flow check valve?
freegeo
If you have the fuel line off of the fuel filter and turn the key to the on position. The fuel pump should run for about 2 seconds and gas should be coming out of the line.
Edited by freegeo, Jan 4 2017, 02:06 AM.
ddave
Thxs. Kinda thought so. Good thing the pump on motor still works
And already have a replacement tucked away. No just gotta wait for warmer weather.
And not brake really hard or take really sharp corners for now!
Edited by ddave, Jan 4 2017, 04:36 PM.
