| Lower AC tension bracket/pulley | |
| Tweet Topic Started: Jan 24 2017, 02:36 PM (1,781 Views) | |
| xzn2p3 | Jan 24 2017, 02:36 PM Post #1 |
Is this piece available or a alternate I can use? Is it possible to just run a shorter belt directly from the AC to the main pulley? |
| suzukitom | Jan 24 2017, 03:31 PM Post #2 |
Tom
Yes its still available. The tensioner pulley assembly is required to make easier, precise adjustments to maintain proper tension for the A/C compressor belt. Example below is for 95 4 or 3 cylinder engines. Same part 95 through 2001 http://m.autozone.com/external-engine/idler-pulley/geo/metro/1995/3-cylinders-6-1-0l-tbi-sohc Edited by suzukitom, Jan 24 2017, 03:35 PM.
| xzn2p3 | Jan 24 2017, 04:28 PM Post #3 |
I need the bracket as well. Literally flew off the car going down the road.
| Dystopiate666 | Jan 24 2017, 04:31 PM Post #4 |
Tree Banger
I have a used one I will sell for $20 plus shipping. |
| xzn2p3 | Jan 24 2017, 04:34 PM Post #5 |
Will fit a 2001 with 1.3? |
| Dystopiate666 | Jan 24 2017, 04:55 PM Post #6 |
Tree Banger
It is off of a 97 3 banger. Suzukitom's post above says "4 or 3 cylinder engines. Same part 95 through 2001" so.... |
| Dystopiate666 | Jan 24 2017, 04:55 PM Post #7 |
Tree Banger
PM me. I have the whole assembly |
| suzukitom | Jan 24 2017, 06:17 PM Post #8 |
Tom
The A/C tensioner idler is the same for all years. The original poster said he has a 2001 Metro which means it should have A/C and power steering. I am a bit puzzled which bracket 'flew off' but I'm guessing its just parts 21-24 in the diagram that you need, and not the entire A/C or P/S bracket (parts 7 and 13) which are bolted to the engine. |
| xzn2p3 | Jan 24 2017, 07:07 PM Post #9 |
No power steering. It's the bracket that the Idler/Tensioner Pulley was attached to. |
| Tusker | Mar 3 2017, 01:26 AM Post #10 |
Are you positive it is the same part? Autozone specifically says it will NOT work on a 1997 Geo Metro 3 cyl. I really need this part as well. (Oddly enough mine just flew off one day too.) I need all the hardware. tensioner, bolt(s), nut(s) belt, and whatever else might be there I'm missing. |
7:55 PM Jul 10
