| High output alternator | |
| Tweet Topic Started: Feb 7 2017, 09:02 AM (593 Views) | |
| crazyndn | Feb 7 2017, 09:02 AM Post #1 |
Figured since the main reason I'm looking for one is for my stereo system, that I'd ask here. Does anyone make one for the '92 generation 1.0? Thanks. |
| Bjetmech | Feb 7 2017, 10:06 AM Post #2 |
A stock replacement? Nope. Do a search for a CS130 upgrade and you will find a lot of good info. There is a kit you can buy. Some lately seem to have an issue getting the order in and getting it delivered. When I bought mine it was around 4 years ago and had no issues. |
| Stubby79 | Feb 7 2017, 10:21 AM Post #3 |
How much juice you looking to run? |
| MR Bill | Feb 7 2017, 10:27 AM Post #4 |
I put the CS130 in my 92 with on problems. I did run a second charging wire (with fuse) to the battery. |
| crazyndn | Feb 8 2017, 07:56 PM Post #5 |
Not much more than stock I'd imagine. Enough to run a possible full amp(4chan/subs) setup and augment with a cap accordingly. Possibly run some auxillary lighting as well. Just don't want to have to invest in a fuse company to justify a good sound system. I will research that CS130 though. Thanks for the info fellas. |
| evmetro | Feb 8 2017, 08:07 PM Post #6 |
Here is a thread on the cs144 alternator. http://geometroforum.com/topic/8035688/1/?x=90#new |
| crazyndn | Feb 8 2017, 10:58 PM Post #7 |
I went and read up on the stock alternator. 55 amps sound right? |
| crazyndn | Feb 8 2017, 11:05 PM Post #8 |
I like that 144 setup too. I do like the better durability you was talking about there. Usable is good, but immortal is always better. |
| Gabes Metro | Feb 15 2017, 11:02 PM Post #9 |
I gotta ask, how are these things wired in our cars I put in a cs130 with volts jumping from 11.0 to 14.5. Don't know if there's a specific way we're supposed to be wiring these things. I've got a 4 ga charging wire going from the alternator charging post to the (+)battery post and another 4 ga wire going from (-)battery post to transmission lug. The alternator "F&L" wires are hooked up to the two factory wires and the "S" wire is bolted with the other charging wires. Any suggestions/advice? |
| Stubby79 | Feb 18 2017, 10:38 AM Post #10 |
| Gabes Metro | Feb 18 2017, 08:12 PM Post #11 |
I'll try that out Stubby. Thank you!! |
| Gabes Metro | Feb 21 2017, 08:04 AM Post #12 |
Alright Stubby, it's looking like the colts are still jumping from 12 to 14.5 albeit less frequently. Is this just normal behavior or should volts be static? Thanks. |
7:55 PM Jul 10
