New member.. another VERY rotted Metro being raised from the dead; Huge restomod project; both horns GONE, rockers, floors, and everywhere else too.
Topic Started: Apr 5 2017, 10:15 PM (4,148 Views)
nwgeo
Swifterthanu
Feb 13 2018, 02:46 PM
nwgeo
Apr 9 2017, 01:08 AM
They are trying to push salt for road treatment up in the Northwest USA...
Don't know where you're at but I'm glad the Salmon and Indians have stopped that in our PNW.
East WA state... nope the fish and Indians are not stopping it, in the snowy areas of East Wa, it is on most of the big store parking areas.
You can thank slip and fall and sue and the attorneys for the start of ruining cars in the PNW snow areas.
Swifterthanu
Teamswift troller
nwgeo
Feb 13 2018, 04:25 PM
East WA state... it is on most of the big store parking areas.
You must be far away from the Columbia because it is illegal to use here in Eastern WA by law. The big store parking lots are private property. I know here in the Tri-Cities that the municipalities have a brine solution that has been approved by the DOT and the Indians for use on the roads. This and sand are the only things that go on the roads here when it snows.
suzukitom
Tom
Swifterthanu
Feb 16 2018, 12:07 AM
nwgeo
Uh.. isn't brine even worse that salt?
In most states, brine is a mix of rock salt (sodium chloride) and magnesium chloride, dissolved in water so they can be sprayed on the road. “That’s a very important point, because magnesium chloride is much more corrosive than sodium chloride, the rock salt,” said Bob Baboian, an auto industry consultant and a fellow at the National Association of Corrosion Engineers.
Snertsky
I'm wondering what the curb weight of this car is going to be after all this steel that's been welded on. This is impressive work. I bet it's more fun for us to watch than it is for you to do, but please don't take that away from us. This is good entertainment :thumb
Swift-guy
Im not sure but why wouldnt you put in galvanized steel? you need proper air mask though but it will be much more rust proof in the future.
Count Metrola
Believe me, the car will get done. My work schedule is absolutely crazy and the weather around these parts has been so consecutively horrid I haven't been able to work on the car. Welders don't function very well in the cold and I especially don't want to chance it seeing as I am welding vital suspension components. Although, today is supposed to be beautiful so hopefully I can get the car closer to being back on all four wheels. Thank you guys so much for all of the support and encouragement. I've had my contemplations... and hammers in my hand, but I surpassed those thoughts and continued fabricating. This car will be completed one day, I promise; unless something goes irrevertably wrong. As always, stay tuned, folks. I'm terribly sorry about the wait
Edited by Count Metrola, Feb 24 2018, 06:18 AM.
Count Metrola
Swift-guy
Feb 16 2018, 03:18 PM
Yes, I agree. But, I would have to grind off the galvanising in order to lay weld properly which, in some areas, is on both sides. It would be in a much smaller location though. I never really thought about using galvanized, honestly. :cheers
pdqrunner
Wait until you see the faces on the guy in the shop that do the front end alignment. They are amazed that people will go to such great lengths to fix these cars. When I did my 96 they announced over the PA the metro has arrived.
Also that beet juice/ brine sticks to the car and plays havaik on you electrical connectors.
MPG
Keep pressing on my Metro friend When finished it'll be worth all your effort :thumb
Count Metrola
Well as of yesterday the lower firewall is completely rebuilt. I have both square tubes done for my custom frame horns, and the c-channel is tacked onto the floors. I have a few spots to patch up front still, but it is so close to being back on four wheels. I ended up ordering new rocker panels too, so those will be getting installed. I'm really excited! It's getting close!
Count Metrola
Finally got a good day to work on the car on my weekend off. The upper frame behind the fender on the drivers side is completely done. The drivers side frame horn is completely done, welded, and welds reinforced by plating over the butt joints. I am also almost done with the passenger side steering rack mount. Furthermore, I got a bunch of little holes patched up front. This project is nearing completion and I can't wait to finally get behind the wheel of it. Since it's been too cold to weld, I started getting the engine ready too. I installed a new water pump, timing belt and idler, rear main seal, and a full tune up kit. I forgot to get a picture, but wow. The water jackets are PRISTINE. I really believe it has 50k original miles. It's unfortunate the nimrod left it sit outside for so long though. It may not have faired this bad. In any case, the project WILL be completed. As always, stay tuned for more. :cheers
I'll get the pictures uploaded later today.
Edited by Count Metrola, Yesterday, 6:55 AM.
Horn
Holy crap! Good work. Idk if you are crazy or smart to take on this project, but it seems you are having fun and learning.
Swifterthanu
Teamswift troller
SuzukiTom you are correct. I can't see how this is getting past the Indians. So I wonder how they will justify this since the big money talk that stops every major road project is the almighty Salmon. I guess the citizenry will have to take the first step and do a class action against the state for theft without reimbursement.
https://www.wsdot.wa.gov/Regions/Eastern/Winter/
Edited by Swifterthanu, Today, 11:37 AM.
Count Metrola
Horn
Apr 22 2018, 06:42 PM
I wouldn't necessarily deem it "fun" 100% of the time, but it is extraordinarily enriching to see something that was completely non-existant before, constructed into a (hopefully) operational structure such as my frame horns. Once I finish the steering rack mount, I should be able to drop it back down on four wheels. There's a lot left to do yet, but there's substantially less to do than when I acquired the car. I really didn't want it to take this long, but several things procured and took precedence over the car. It's getting there though, and I'm learning quite a bit. :cheers
