YouTuber uses expanding foam for sound deadening.
Topic Started: Apr 7 2017, 01:41 PM (710 Views)
clen
Buy 'Em Up! Now!
So the youtuber Brad Majors had two videos.
Geo metro before sound deadening
After Geo metro sound deadening
Has anyone done this? Is it worth it as foam is really cheap.
Is it worth it. I guess for a beater then maybe.
1DCGUY
Don't be a "Richard"
clen
It works great for deadening sound, but it is horrible for rust!!
The water and muck gets trapped behind the foam and it rusts faster than with no foam.
clen
Buy 'Em Up! Now!
I'm assuming you only use it for internal structures and I guess you have to water proof it somehow.
geopat
1DCGUY
Apr 7 2017, 02:16 PM
clen
Plus when you go to fix the rust the foam likes to catch on fire. Some manufacturers do this from the factory and I have had to repair them it is not fun.
t3ragtop
i refuse to weld on cars that have taken this abuse. heat from welding causes the foam to produce poisonous gas.
i won't die for any rusted out shit box of a car. ;)
bkgeig
Banging on a panel and saying it "makes a big difference" isn't really very enlightening. Difference in what? If open- or closed-cell foam was an effective noise blocker, you'd expect to find it used in building applications like sound studios.
Here's a good overview to soundproofing: http://www.soundproofingcompany.com/soundproofing-articles/foam-or-fiber-insulation/
Dominus2010
Newbie
well this was me in that video. yes it is true that if you have to weld on it then it does release gasses. BUT i wont be welding on it ( hopefully lol ). it is the best for covering LARGE areas that you need to deaden and make rock hard. you do have to realize that what im doing is NOT for every day use. This car was purchased SOLELY for the purpose of audio competitions and i need the car to be as solid as possible without pouring concrete in it. If i was to be using this as a dedicated daily driver i would just put down butyl mat sound deadener only on the panels. I do not intend on letting ANY water get to these areas unless I develop some level of rust in which case ill probably just fiber fill. this is not the only level of protection and or deadening that this car will see by a long shot lol. this was just solely to make the panels rock hard so that i dont literally shear them in half from vibrations. anywho if you need any info id be more than happy to help as many of these other fine lads have as well.
PTA2PTB
Dominus2010
Apr 10 2017, 07:20 PM
Will the car float?
Dominus2010
Newbie
PTA2PTB
Apr 10 2017, 07:28 PM
Dominus2010
Will the car float?
probably lol. secondary purpose noted ^_^
clen
Buy 'Em Up! Now!
Hey Dominus, keep the videos coming. I would really like to see how the project progresses.
Dominus2010
Newbie
i will. it will be slow progress as i work full time and in college full time as well ...family ...kid ... all that business lol but once im out of class i will have alot more time and i will attempt to make a lot more progress. but i have build thread going right now with all the things so far that i have done to it and will continue to post there along with videos on my youtube channel. thanks for the support :)
Dominus2010
Newbie
holy cow.... just seen this post was almost 1 year old.... lord the amount of work ive done to the geo lol i need to post a new video showing where shes currently at
