Skips bucks hesitates alot; Help
Topic Started: Apr 20 2017, 10:31 PM (144 Views)
Tommy0521
So i drive my metro probably 40 miles to work a day haul the kids to soccer school ect. It was running funny skipping bucking hesitation sounds like a 2 cylinder i changed coil plugs wires cap checked the timing and the marks all line up now if i set it were my hood says 5 degrees it runs worse no power bucking still stalls. My question is could it be internal :banghead
suzukitom
Tom
What engine is in your 2000 Metro. Do you have a 3 or 4 cylinder engine?
(1) Does it run any differently when it is cold vs. hot?
(2) A compression test would provide an initial idea of the internal condition of your engine and what to do next.
(3) Did you check for any loose or dirty wire connections (Eg. Ground wire(s), TPS sensor connector, O2 sensor connector, etc.)
How long since the fuel filter has been changed?
