1997 geo metro coupe ac trouble; Where to recharge or replace?
Topic Started: May 20 2017, 12:26 AM (191 Views)
geometrogang
Okay, first things first...... Does my 1997 geo metro coupe even have air conditioning? if it doesn't, how can i put an air conditioning system in it? If it already does have an ac system, where is the low pressure valve? I've been trying to find the low pressure valve for the longest, and i can't find it. Probably the most boobish question on this post, but where is the ac compressor located? I NEED HELP!!
p.s- this is my first post and this is my first geo :cheers
Welcome!
Gonna have a button marked A/C on the lower right corner of the heating control panel, if not, it will have a little half inch square vent in that spot. It's also going to have what looks like a second radiator on the passenger side, non A/C cars have a flat metal plate there blocking air. If you look at the passenger side of the engine near the bottom, you'll see a big pulley with belts on it. All Metros have one belt which goes toward the rear and runs the alternator and water pump. Fancier Metros have a second belt which goes toward the front and runs the A/C and/or power steering.
A/C can be added, but it's a pretty big job. Best to have an entire car to steal parts from. If you need to ask these questions you're probably not up to doing it yourself, but this is a pretty helpful place, you might be able to find someone here who would help you.
Edited by Woodie, May 21 2017, 04:24 AM.
