A/C Question :)); Watch video
Topic Started: Jul 5 2017, 05:49 PM (179 Views)
PrettyGurlUglyCar
Mel's LiL "Vessel" ;) 199K
https://youtu.be/zjnO5Rk03O4
Thanx for your help :D
MR1 Kingsbury
Exp. builder/rebuilder
to charge with new 134a, you will connect to the low side under the cap marked L. start the car turn ac on high, let run for 2-3 minutes then connect your product to the low side. Pull the trigger or open the valve, and slowly rotate the can while it fills the system.... The gage on the frigerant should let you know when it is good. fill to near the top of the green zone if its over 85 degrees out. might not need the whole can full.
