Equipping a 91 metro with AC; What I have and what I need.
Topic Started: Jul 7 2017, 10:24 PM (285 Views)
coreyare
I got a 91 metro, and am making it a project car of sorts. Stock wise, it is unequipped with air conditioning, so naturally, I am looking for parts as I am unable to utilize a donor car :(
Anyone here have some of these bits available?
Parts I need:
Harness (interior and underhood)
Brackets for compressor and all peripherals (this seems to be a biggy D:)
Lines (already have the line with the sight glass)
Accelerator switch and any other switches and relays
Parts I already have or are easily available on the market:
Evaporator box
on/off switch
vacuum switching valve
compressor (need to buy)
condenser fan (need to buy)
condenser (need to buy)
reciever drier (need to buy)
geogonfa
First...Welcome to the Fun :greet
Next...when looking for hoses and hard parts I would suggest looking for '94 hard parts (hoses and cores), because they were designed for 134a freon and will fit your '91...
the parts needed...
compressor
compressor bracket
Belt
idler pulley and bolt assm.
low side rubber line
high side rubber line
condensor
condensor fan
receiver/drier
receiver/drier bracket
cond. to drier pipe
drier pipe joint (sight glass)
drier outlet pipe (one that attaches to the pipe joint)
condenser inlet pipe
compressor liquid line
both short lines that go through the bulkhead to the evap core
evap core
evap case
a/c amplifier
expansion valve
evap core temp sensor
under dash wiring
under hood wiring
2 relays for the power distribution box under the hood
30 amp fuse
vacuum switching valve and bracket...
Accelerator cut off switch for gas pedal
dual pressure switch for the a/c (goes on the liquid line)
and even though your metro didn't come with a/c it probably has the overheat/cut off switch already mounted into the lower intake right above the alternator...
We have a lot of members up that way so hopefully you can find what you need...if not, I have a lot of this but cost and shipping could get expensive...
Happy Hunting...
coreyare
What do you have, and if I can't seem to find any washingtonians with these bits, what would we be looking at costs? the hardest bit seems to be the pressure switch, and the lines, I have the bit that has the high side fitting on it, and a whole evaporater core with lines that come out of it, as far as lines are concerned :D
accelerator cut off switch sounds nice....
wire harness is a maybe....if i could find out pinouts I may be able to jerry rig something up lol
suzukitom
Tom
coreyare
Jul 8 2017, 09:53 PM
Wiring connectors for early Japan built Swifts, Sprints and Metros may be in place to support dealer installed A/C kits.
Try looking at the A/C section of the wiring diagrams for for a 91 Swift here:
http://metroxfi.com/wp-content/uploads/2008/12/suzuki_swift_1991.pdf
coreyare
Thanks for the aid folks, found a inside wire harness.....Anyone have a bracket, and lines? lol, I have the line that has the hi side fitting on it
