| A/C Knob Replacement :)))) | |
| Tweet Topic Started: Jul 21 2017, 02:28 PM (380 Views) | |
| PrettyGurlUglyCar | Jul 21 2017, 02:28 PM Post #1 |
Mel's LiL "Vessel"
;) 199K
Hi I just got this car's AC serviced and now the knob that you see doesn't have any tension so the blower cannot be turned on so I was wondering after I pulled it out I can't see how to get in there to either fix it or buy a new one so any suggestions would help me thank you you guys are great!! It WAS workin but I noticed "Blower" would shut OFF for about 10 seconds & turn back on but I didnt think it could be the "Lever" which has NO tension now so blower CANT be turned in videos belowhttps://youtu.be/vvMIvhGWKQA |
| suzukitom | Jul 21 2017, 02:38 PM Post #2 |
Tom
It looks like the fan switch broke. There is a good write up here. http://geometroforum.com/topic/4541259/1/ |
| Johnny Mullet | Jul 21 2017, 07:05 PM Post #3 |
That write-up has some pics missing, but you can do this and you gotta be patient. After the fan switch is accessible, carefully take the top off the switch. Inside you look carefully and will find a tiny little ball. Find the ball, pull the lever out of the housing, and look for the spring. The ball is what makes the "click, click, click" of the fan selections. You need to get that ball between the housing and the spring and get the lid back on without it coming apart and losing the ball again. Once the cover is on, use a zip tie that fits around it like the pic in the thread Suzukitom posted and make that zip tie tight. It will work again and won't cost anything but your time
| Stiffchezze | Jul 21 2017, 07:14 PM Post #4 |
Sir Metrologist
Pics missing? ..............SON OF A ........... I'll try to get it updated this weekend........(maybe) |
| Metromightymouse | Jul 21 2017, 11:55 PM Post #5 |
Press the top down and see if the switch works properly (the click click) before pulling the top off. If it works just zip tie it, if it doesn't follow Johnny's suggestion. |
| Woodie | Jul 22 2017, 06:56 AM Post #6 |
You're better off going through the glovebox. |
| MR1 Kingsbury | Jul 22 2017, 09:33 AM Post #7 |
Exp. builder/rebuilder
Oh yes... I found that the be pretty easy. much easier to leave it tight and stabalized, then get the pliers and ziptie around it while it is in place.. I think her ball and spring has sprung, so she will have to take it apart to rebuild the internal.. |
| Dystopiate666 | Jul 22 2017, 09:36 PM Post #8 |
Tree Banger
it will work without the detent ball too, you just lose the indicator click that tells you you went to the next setting |
videos below
7:54 PM Jul 10
