OVERHEATED REAL BAD; I need help figuring out how much damage I did
Topic Started: Aug 27 2017, 10:46 AM (659 Views)
dustinterror
I want to thank all of you guys for all of your help! However after realizing how much damage was done I turned to craigslist to search for a new one. I could not believe what I found. 95 3/5 4 door. 221k on the body, 87k on the engine. The man owned it for the last 12 years. Used it as a commuter to work and back. Just retired 3 weeks ago and decided to sell it. It came with the absolutely most overkill maintenance record I have ever seen. I feel pretty lucky at this point.
Dystopiate666
Tree Banger
Score. Pull the trans out of your junker for a backup and learn how to rebuild that engine on your shelf so you can do an assembly swap next time you have problems (trans and engine)
dustinterror
Sep 10 2017, 09:14 AM
95 3/5 4 door.
You sure about that? There's not supposed to be such a combination.
Edited by Woodie, Sep 11 2017, 05:37 AM.
MR1 Kingsbury
Exp. builder/rebuilder
dustinterror
95 3/5 4 door.
good catch woodie. I didn't even consider the 4 dr concept on a 95 would certainly be the heavy sedan with 3 cyl not available.
It could very well be a swap job. I've seen a couple sedans trying to survive with a 1.0 5 speed.
Edited by MR1 Kingsbury, Sep 11 2017, 09:41 AM.
j63812f
J R
It's probably ruined get another engine from Geo Glenn
1DCGUY
Don't be a "Richard"
j63812f
Sep 11 2017, 07:54 PM
:gp :thumb :thumb
:evillol :evillol :evillol
