Locate ODB Sensor pin + no start problem; cannot find pin adapter ?
Topic Started: Aug 28 2017, 12:53 PM (533 Views)
freegeo
What makes you think the pcm is going bad on the car?
FortunaMetrona
:popcorn
so., brought my geo to two different mechanics... The one that said I had an ECM problem, from last post, I went to another mechanic... That now says that the fuel injector is clogged and should be replaced, (because they do not clean injectors)... So, I did a seafoam gas treatment 1/3 can and 1/3 can into the throttle body. Drove for 3 hours, ( big improvement on engine ) But parked it and the next day ,,, Wouldn't start ... again.... thinking I may have a short in wires or something else... Any input would be great...
freegeo
Since it won't start, you need to check if it is not getting fuel or spark.
