| gas leak front of geo metro lsi; gas leak | |
| Tweet Topic Started: Sep 4 2017, 02:11 PM (190 Views) | |
| lea | Sep 4 2017, 02:11 PM Post #1 |
I have a gas leak on geo metro lsi, seems to be in the front of the car,,gaslines back to fuel tank are solid,,drivers seat forward is the leak area,,i need the gas line path way |
| freegeo | Sep 4 2017, 03:16 PM Post #2 |
The fuel lines are metal under the car from the front of the gas tank, run long the bottom of the car with the brake lines and come up onto the firewall. If I remember correctly rubber hoses attach from those fuel lines to the throttle body. If the metal lines are not leaking then check the rubber hoses. If you can actually smell gas you need to get it fixed before driving on the road. Hate to see you post something in the future about your car caught fire. |
| freegeo | Sep 4 2017, 04:36 PM Post #3 |
| leasied | Sep 20 2017, 09:18 AM Post #4 |
ok the fuel regulator is connected to the black boxs (marked as 18560-60B00),,im thinking that the black box is some kinda of a air supply ,because it goes into into the frame of the car,,and this is where the gas is leaking from ,,would it be maybe the regulator? |
| freegeo | Sep 20 2017, 09:51 AM Post #5 |
The fuel pressure regulator is inside the throttle body. Are you talking about the black plastic container attached to the firewall? It sounds like you are talking about the evap canister. There is a hose that attaches to the bottom of it and goes over the frame horn area.
Edited by freegeo, Sep 20 2017, 09:59 AM.
3:49 AM Jul 11
