| Overheating? NOT?; Phantom overheating | |
| Tweet Topic Started: Sep 13 2017, 03:04 PM (773 Views) | |
| Foster | Sep 21 2017, 08:21 AM Post #16 |
Have ordered a new radiator, should be here next week. Will ley you know how that works out after I get it installed. |
| MikeJ | Sep 21 2017, 11:16 AM Post #17 |
Mike J
My 96 3/5 No A/C 190K mi was running great. Began moving the gauge needle to just under the top white line during 20+ mi summer trips. Outside of that no other problems. Went through the cooling system same as you swapping with a known good radiator on another 200k mi car. No change. Out of desperation I swapped out the cat converter off the same 200K mi car. The overheat issue went away. I hope the radiator change fixes yours. |
| Dystopiate666 | Sep 21 2017, 12:41 PM Post #18 |
Tree Banger
Backpressure causing overheating eh? |
| Foster | Oct 6 2017, 09:56 AM Post #19 |
Sorry, should have posted sooner. Put the new radiator in, took it for long trip hitting long inclines. air temp was 80+ degrees, needle stayed right in the middle of the gauge. Check the radiator with the IR thermometer, no cold spots. I think the problem is fixed. Thanks again for all the good advice. |
| Dystopiate666 | Oct 6 2017, 12:06 PM Post #20 |
Tree Banger
7:54 PM Jul 10
