| Rotor button design | |
| Tweet Topic Started: Sep 20 2017, 08:20 PM (183 Views) | |
| Red_Rocket | Sep 20 2017, 08:20 PM Post #1 |
I finally replaced my plugs, wires, cap & button tonight! I am/was(?) experiencing pinging at certain times and I hope this helps. The clip on the old button was situated over the flat spot on the distributor so I I put the new one on I oriented it the same way. It would not go one and I realized that the contact would have been on the wrong size. There also plastic ridges in the new one and that's when I realized that I just need to turn it 180 for it to go on. The ridges create a flat spot to match up to the spot on the distributor. It fit on fine and seems to run fine. Is this just a different design? The new is made by Standard and is the black one in the pic. It seems to be ok from a short test drive, but I just wanted to get some input and hear someone else say it's just a different design. Thanks, -RR |
| Crvett69 | Sep 20 2017, 08:45 PM Post #2 |
black one need to be rotated 180%. the metal part is not the flat locater its the 2 small tabs you can see partway down inside that goes to flat spot on dist shaft |
| geogonfa | Sep 21 2017, 10:52 AM Post #3 |
Just my .02ยข...just a different design of where the tension spring is located...it should be fine...
| Red_Rocket | Sep 23 2017, 06:13 PM Post #4 |
That's what I thought, just wanted to hear someone else say it. Thanks! |
3:49 AM Jul 11
