O-Ring and Freeze Plug size list
Topic Started: Sep 29 2017, 01:13 AM (602 Views)
Wolf
Thought it might be helpful to list some of the O-ring and freeze plug sizes for Metros in one place. If anyone has sizes for locations I missed, or if I made a mistake feel free to chime in. :cheers
O-Rings:
Metros were designed for JIS (Japanese Industrial Standard) size O-Rings.
Sizes below are in millimeters and listed as: Outside Diameter, Inside Diameter, Cross Section .
Distributor base (JIS P24):
30.7 x 23.7 x 3.5
Water pump outlet pipe (JIS P28, aka GM part# 96059933):
34.7 x 27.7 x 3.5
Automatic transmission solenoid wiring harness plug (JIS P18):
22.6 x 17.8 x 2.4
Oil pump intake tube (JIS P14):
18.6 x 13.8 x 2.4
Oil dipstick tube (JIS P10):
13.6 x 9.8 x 1.9
Speedometer cable at transmission (JIS P14):
18.6 x 13.8 x 2.4
Freeze Plugs:
Given sizes are actual hole sizes (1.0L). Some catalogs list by plug size which are usually around 0.5mm larger.
Steel plugs are preferred for Metros since brass can supposedly have a corrosive reaction with aluminum.
As of 9/2017 O'reily Auto Parts was able to order all these sizes (next-day) for less that $1 each.
Head: Timing Belt side Large= 40mm
Head: Timing Belt side Small= 25mm
Head: Radiator Hose side= 20mm
Intake Manifold: Underneath= 30mm
Intake Manifold: Left and Right= 20mm
Edited by Wolf, Oct 14 2017, 04:58 PM.
Wolf
Added speedometer cable o-ring. It's the same as the oil pump tube :)
Mythstae
Geo Metro O-Ring Information
Coolant Tube:
GM P/N 9605-9933
Suzuki P/N 09280-28008
ID 27.7mm, Dia 3.5mm
Distributor:
Suzuki P/N 33278-54E10
ID 23.7mm, OD 30.7mm, Dia 3.5mm
Oil Pickup Tube:
Suzuki P/N 09280-14011
ID 13.8mm, Dia 2.5mm
Dipstick Tube:
Suzuki P/N 09280-10016
ID 9.8mm, Dia 1.9mm
Part numbers to purchase from McMaster-Carr:
http://www.mcmaster.com/
93125K71 Coolant Tube O-Ring (3.5 x 27.7 ID)
93125K39 Oil Pick-up Tube O-Ring (2.4 x 13.8 ID)
93125K27 Oil Dipstick O-Ring (1.9 x 9.8 ID)
93125K61 Distributor O-Ring (3.5 x 23.7 ID)
greengeo1995
Tree Shade Mechanix
Hi GMF!
how about this please? (photo attached below)
from a transmission; O-ring underneath
far end driver side,thanks!
Edited by greengeo1995, Jun 11 2018, 11:07 AM.
freegeo
greengeo1995
Jun 11 2018, 10:41 AM
Hi GMF!
Looks like # 12 in the picture.
GM part number is - 96057198
Attached to this post:
Attachments: manaul_trans.jpg (110.34 KB)
Edited by freegeo, Jun 11 2018, 11:28 AM.
freegeo
Still searching.
Have not been able to find a size for that part. You may have to measure the grove in the trans and then the thickness of the oring to get one.
Edited by freegeo, Jun 11 2018, 11:42 AM.
David95237
I have those in stock. Give me an address and ill ship you one. no charge.
Edited by David95237, Jun 11 2018, 12:57 PM.
