Downgrading to a carb engine?
Topic Started: Sep 29 2017, 11:27 PM (373 Views)
rbralien
How hard would it be to convert lets say a single point TBI engine (1.0L) in my 90 Metro, into a carburetor engine, assuming I could find the parts and what parts would need to be changed?
Dystopiate666
Tree Banger
Electronic fuel injection was one of the greatest advancements ever made to automobiles...why would you ever want to go back to a carb?
Pretty sure all you need is about 3 feet of straw, this way you can just spit fuel at it from the drivers seat.
hovernutts
I have a 1 liter Suzuki in a hovercraft. I use a Solex carb and the intake is bored out to accept the carb.and I use an off the shelf elec. fuel pump
rbralien
Well I was thinking of having the spare parts around just in case TSHTF scenario. Not wanting to open a debate here, just was thinking out loud, cause my 90 Geo isn't far from all manual. I would think the distributor and carb would all that would need to be changed, and add a few vacuum hoses and disconnect some others. Fuel pump would still have to be electric I would think though.
t3ragtop
even with a vacuum type distributor you'll need to keep a distributor module in a steel ammo box. ;)
Crvett69
Some of the jdm engines I used to get from Japan came with carbs. Not sure what cars they came out of. Still have one of the carbs and intake setups
freegeo
Crvett69
Oct 15 2017, 12:24 PM
Do you remember if it had a mechanical fuel pump on the engine or do you think it had a electric type on the car?
Crvett69
Rest of the engine head and block were same as ours so it had some sort of electric pump
nwgeo
The MK1 series were all carbed. Already done for you.
dpish
t3ragtop
Oct 15 2017, 11:36 AM
and electric fuel pump
