engine donuts
Topic Started: Oct 1 2017, 03:59 PM (236 Views)
Crvett69
do those removable rubber donut type things on the engine and tranny mounts serve any purpose besides falling of duting instalation to annoy me?
i always figure that there is a reason for everything.
Crvett69
i thought they might have something to do with the machinary they used to install the engines during assembly
geogonfa
Best guess... :hmm ...to help prevent oil and gear lube from contaminating the rubber mount material...
suzukitom
Tom
The donuts are also there to dampen severe fore and aft, or side to side movements that could otherwise allow the mount to slam into the ends of their respective metal brackets.
You will also see these donuts on the control arm bushings.
Dystopiate666
Tree Banger
Beer coasters
Crvett69
never seen them on any of the metro control arm bushings i have worked on
suzukitom
Tom
Crvett69
Oct 2 2017, 06:38 PM
I probably should have clarified that the control arm bushings have the same function as the donuts on the motor mounts.
On Swifts you can buy the control arm bushings separately, lube them with soap and press them onto your control arms. I call the ends of these bushings donut washers.
Part 27 in the diagram.
Attached to this post:
Attachments: Controlarm.png (82.35 KB)
Edited by suzukitom, Oct 3 2017, 12:05 AM.
