| Engine damage?; Ran on 1.25 qts for unkown time | |
| Tweet Topic Started: Oct 11 2017, 09:29 AM (240 Views) | |
| smysmbrg | Oct 11 2017, 09:29 AM Post #1 |
SteveO
My friend I have been helping out with his 97 4cylinder autotragic came to my house last friday for an oil change. I fixed the cam,crank and distributor seals but told him he needed to check the oil!!! Drained the oil and the filter and got about 1.25 qts out. Now he wants to sell me the car because checking the oil is too hard For him. He has spent about 3,000$ on this car at the shop is what he tells me. I am going to test drive the car all day at work today to see how much oil its using and see what kind of milleage I can get. (Also assuming the 4 cyl valve seals are leaking, common right? And due to a puff of smoke on startup) It does have a smaller rust hole on the passenger frame horn. My thinking is that it could replace my aging winter beater since the car only has about 85,ooo miles. He is hoping to get 500$ for it Then he can have $ for a down payment on a more expensive car to wreck (says its going to be a insight or a echo for 3,000$) Meanwhile his 2011 avenger only sees lyft duty because he doesnt want to put miles on it doing delivery. |
| Me and my metro | Oct 11 2017, 10:46 AM Post #2 |
I have seen cars run low on oil continue to run with no problems. I have also seen the aftermath of running them out of oil. They usually have only a few rods still connected to the crank. So if it is quiet it is probably still ok. |
| snowfish | Oct 11 2017, 11:20 AM Post #3 |
If it doesn't rattle, you're probably fine. I would ignore the puff of smoke at start up. If it drives, sounds good, and handles to you satisfaction, you've probably got a decent winter car. Run some good oil, put on a JT Brace, get a 4 wheel alignment, and run it. For city driving, fuel mileage should be pretty close to the 3 cylinder automatic. Be sure to post up some pictures when it's yours. |
| smysmbrg | Oct 11 2017, 12:19 PM Post #4 |
SteveO
Sound advice literaly. Car sounds good. Struggles a little on startup. My guess is that it goes thru a quart every 1,000. Do know that synthetic burns cleaner than conventional, so less likely to burn valves up quickly. Guess it will depend on what milleage i can get at work today. Car has brand new ac compressor and condensor. |
| snowfish | Oct 11 2017, 01:28 PM Post #5 |
Probably just need a fresh set of sparkies. 1qt every 1000 miles? My 2 stroke sled goes through more than 2qts every 1000 miles. Buy, run it, and if you don't like it next fall, you have a Great Baja Car for the county fair! |
| Moringa | Oct 11 2017, 02:07 PM Post #6 |
Living BOT
Is the 1.25 qts just what you drained, or did you pour the oil out of the filter, as well? You might want to ask the guy what kind of oil he used. Synthetic is so much better, that the chance for bearing damage is a whole lot less, when it gets low. The best time do determine bad bearing clearance, is when you start up, right after an oil change. For 3 or 4 seconds, you have no oil pressure, because the filter is empty. If you don't hear anything then, you are probably in good shape. |
| smysmbrg | Oct 11 2017, 11:06 PM Post #7 |
SteveO
Well it didnt make any noise when It was started after the oil change. I dont think its burning oil too bad, maybe 1/2 qt in a 1000 or so. I got 35mpg city today so I am going thru with the purchase. He wants 700 wich is fair really just needs a set of tires and it will be rolling good for a while. Now I just need to sell my 1990 civic hatch winter beater and possibly my 92 3/5 because 5 cars is just to many when you live in the city and have to park some on the street. Edited by smysmbrg, Oct 11 2017, 11:07 PM.
| Scoobs | Oct 11 2017, 11:11 PM Post #8 |
How did you find out it was low? Was the oil light on? If it wasnt on at any point, then your probably ok. Aprils car i drove it one day and made a turn into my work and the oil light came on, i checked and the dipstick was bone dry. That was the first time the light came on, and its still driving like it was. (shitty) Made no effect on it. Again, the light only came on making a sharp turn and went away as i straightened out, and then i added 4 quarts of oil as soon as i pulled into my work. |
| smysmbrg | Oct 12 2017, 12:34 AM Post #9 |
SteveO
I found out it was low when I did his oil change last week. Only little came out and none on the stick so I measured what was left. Would have been nice for him to have an oil light. I assumed metros didnt have a low oil light could it be a low pressure light? Checked it today and I dont think I let it drain back into the pan long enough after shutting it off. It registered slightly above halfway in the safe zone. Put in just under half qt checked it 120 miles later after letting it sit and it was slightly overfull. Probably didnt help that I only had 1 qt of mobil 5w30 full syn when I did the change so I used that plus 2 qts of mobil 5w20 full syn plus a half qt of federated 5w30 syn blend Going to try some lucas full syn oil stabill mixed with mobil full syn. My dad really likes the lucas full syn oil addative. Also thinking about trying some full syn 0w40 but dont think it will make a noticable difference. |
| Metromightymouse | Oct 12 2017, 12:55 AM Post #10 |
It's a low oil pressure light. No low oil level light on a Metro. |
| Dystopiate666 | Oct 12 2017, 03:24 AM Post #11 |
Tree Banger
Doing a compression/leakage test couldn't hurt..... |
| Hanuman | Oct 17 2017, 02:54 AM Post #12 |
It's th3 change engine light
3:49 AM Jul 11
