| Update on the 18 gremlins.. | |
| Tweet Topic Started: Oct 15 2017, 03:34 PM (212 Views) | |
| Han-Tyumi | Oct 15 2017, 03:34 PM Post #1 |
https://m.imgur.com/17J1iQD This is what I have left. These two wires. It cranks but won't start. Im not getting any spark. It will sputter upon cranking but thats it. Wat do? |
| Han-Tyumi | Oct 15 2017, 03:43 PM Post #2 |
Also, the 3 cylinder 1 litre from a 1995 metro is non interference, correct? |
| suzukitom | Oct 15 2017, 04:02 PM Post #3 |
Tom
All stock Metro 3 cylinder engines are non interference |
| freegeo | Oct 15 2017, 04:15 PM Post #4 |
What distributor did you use on the 95 engine? Can you give the wire colors of the ones you have left? |
| Han-Tyumi | Oct 15 2017, 05:15 PM Post #5 |
There's a picture first sentence of the post of the wires |
| freegeo | Oct 15 2017, 05:36 PM Post #6 |
Sorry I couldn't tell using my phone. Maybe someone else can help you |
| Crvett69 | Oct 15 2017, 06:17 PM Post #7 |
Those do not look like stock wires or the stock plug they go into |
| Metromightymouse | Oct 15 2017, 06:46 PM Post #8 |
That's an added on relay. Could be for the clicky starter issue or for the headlights or something someone added. |
| 92blumetro | Oct 15 2017, 09:17 PM Post #9 |
hook one of those wires to ground and the other to power, see what turns on maybe a aftermarket fuel pump relay? gotta love mystery wiring! |
| freegeo | Oct 15 2017, 10:37 PM Post #10 |
Yes that is a aftermarket relay. Hard to tell what they had it hooked up to. You are not getting any spark at all? Does the check engine light come on when the key is in the on position. The distributor looks like it is set to almost the full retard position. |
| suzukitom | Oct 15 2017, 11:19 PM Post #11 |
Tom
And double check your rotor, cap wires and firing order. Pictures courtesy of Bad Bent: http://geometroforum.com/topic/5018820/1/ |
| ptcapboy | Oct 17 2017, 12:44 AM Post #12 |
excellent idea! |
| MR1 Kingsbury | Oct 17 2017, 06:24 AM Post #13 |
Exp. builder/rebuilder
Might be turning on a 12V arcwelder... |
| freegeo | Oct 17 2017, 09:25 AM Post #14 |
That is 1 possibility. |
3:49 AM Jul 11
