injector cleaner; Not fuel treatment
Topic Started: Oct 17 2017, 12:53 PM (202 Views)
freegeo
Who has used a fuel injector cleaner and what brand name did you use? I'm not looking for the type you add to the tank but the type you would use in a external canister and clean the injector either as the engine runs or with the injector removed.
t3ragtop
i like ethyl alcohol. strip the injector of as much plastic as you can, pull the filter basket and o-rings. put the injector into a baby food jar and pour in the alcohol, removing as much air space as possible before screwing on the lid.
submerge the jar under water in an ultrasonic bath and power it up. the water bath conducts the ultrasonic energy through the glass and into the ethyl alcohol where it mechanically agitates the injector and aids the chemical process.
if you just use the alcohol as a bath, the ultrasonic action quickly evaporates the alcohol. doing it the way i described lets you use the alcohol many times without much loss. ;)
freegeo
Thanks for the suggestion. I have everything but the baby food jar.
t3ragtop
use a jelly jar. ;)
freegeo
Thanks for the ideas. The small jar should help from having to use as much cleaner.
Edited by freegeo, Oct 18 2017, 12:35 PM.
MR1 Kingsbury
Exp. builder/rebuilder
or a little mushroom jar, or an olive jar... I was thinking plastic film canister. but I guess no one has those anymore.
freegeo
Good ideas.
t3ragtop
glass is great for passing through the ultrasonic power. plastic not so much. ;)
