gasket part number needed
Topic Started: Oct 24 2017, 08:37 AM (110 Views)
92MHB
so-- my thermostat housing gaskets are leaking and I can't seem to be able to sift through all the "search" posts to find the right gasket numbers I need
1992 metro hatchback 3cyl
looking for the gasket for the block to housing, and also the gaskets for the thermostat housing
Help?
geogonfa
AutoZone...O' Reily's...Amazon...Rockauto... :type
Felpro Thermostat Gasket (Outlet gasket)
Price: $1.99
Part Number: 35365
Felpro Thermostat Gasket (Housing gasket)
Price: $5.99
Part Number: 35451
92MHB
well, I never know if oreilys, RA, etc actually have the correct part numbers listed anymore----as I have bough parts from both Oreilys and RA that were shown as the correct fitmenet but were actually the wrong parts and would not work
what about the felpro#35588 96 sohc dodge neon gasket I have sen here???
freegeo
It depends on what type thermostat housing you have on the engine if it needs the rubber seal or not.
geogonfa
These are the numbers I use and have not had a problem...as for the neon rubber seal that is used on 95+ and on certain thermostat housings...
Here is more clarification: :type
http://geometroforum.com/topic/5087079/1/
92MHB
thanks-- ordered :-)
