Emissions OBD 2
Topic Started: Dec 20 2017, 02:40 PM (1,164 Views)
menc
Will not pass inspection....Catalyst,,EGR system,,02 Sensor ALL [3] Not Ready...Gas gauge does not work...Where do i BUY a Fuel tank sender Unit,,,this appears NOT TO BE apart of the fuel pump...THANK YOU... 1997 2 door metro small block...............The problem is it WILL NOT PASS INSPECTION.....
Edited by menc, Dec 21 2017, 11:18 AM.
Moringa
Living BOT
The 95 was OBD1. Do you want advice on the Toyota?
freegeo
His post states it is a 97 2 door. hopefully it is a metro.
menc
It is a METRO,,,,,a 1997,,,,,3 cylinder,,,,OBD 2 for sure ....I apologize for the confusion.........I hope someone
can help....... My toyota was stolen and found waded up.....THANK AGAIN..........mcnc
Moringa
Living BOT
He did. . .and called it mcnc. Let's see, "Metro convertible North Carolina" I guess.
freegeo
I checked rock auto and none was listed for a 97.
Have you done any trouble shooting to see if it might be the gauge or wiring that is bad?
menc
I Have not troubleshot yet. The emissions are my main concern...With 3 items not ready ???You have to have 1/3 or more gas in tank for The PCM to be READY to test catalyst,,,,,,the egr,,,,,02 sensor......Tomorrow i am going to drop the tank to check fuel tank sender OHMS output......I should also be able to check the dash gauge by grounding the sender unit wire....That should read a full tank....thank for your comment....
Moringa
Living BOT
On most vehicles, the gas level should be between 1/4 and 3/4 full, for the EVAP monitor to run. The fuel level has no effect on other monitors, like the ones you mentioned.
freegeo
If you need a procedure for checking the fuel gauge and system I can check the 97 FSM and post what I find
freegeo
This is from the 97 FSM.
Attached to this post:
Attachments: fuel_gage_1.jpg (107.39 KB)
Attachments: fuel_gauge_3.jpg (97.85 KB)
Edited by freegeo, Dec 20 2017, 11:25 PM.
Anything you want to check on the top of the gas tank can also be checked underneath the rear seat. It's a lot easier to get to. If you find the voltages going in to the tank are good, but coming out is not, then drop the tank and look into the sending unit. It's more likely a wiring problem though and dropping the tank is a pain.
freegeo
You stated the emission failed since it was not ready. Do you know if the engine is going into closed loop? The check engine light is not on or any code stored in the PCM?
menc
Failed emission . Inspection report says catalyst,EGR,02 senor are NOT READY.The car was driven from Texas to NC,1400 miles not stop. I have been told that the PCM will not perform these [3] test with the gas gauge on empty...Moringer post #8 fuel level has not effect on these 3 test..WHO IS RIGHT??????? check engine light is not on. I was TOLD it showed no CODES...thank you all
MR1 Kingsbury
Exp. builder/rebuilder
menc
Dec 21 2017, 11:31 AM
actually both are correct. The pcm will not perform these system tests without at least 1/3 a tank.
And
The fuel level has no effect on the test or results, that is if the tests are performed....
the pcm decides when to do tests and with a dead fuel gauge, it decides not to run all tests.
suzukitom
Tom
I'm pretty sure the O2 sensor has no dependency on minimum fuel tank level, but the O2 sensor itself might not be working, which could prevent the other 2 systems passing their readiness tests.
Edited by suzukitom, Dec 21 2017, 12:46 PM.
