Transaxle ID; 1991 XFI, 5 speed.
Topic Started: Jan 10 2018, 03:43 PM (238 Views)
sweetcarl
I'm going to replace the passenger side drive axle/cv assembly. I do not know which transaxle is on my car. M42, M58 or is it the MV2? Where will I find the ID for the correct drive axle?
David95237
Its an mv3.
freegeo
David95237
Jan 10 2018, 04:39 PM
Its an mv3.
Were did you find it classified as a MV3? My micro fiche shows it as a MV2.
smysmbrg
SteveO
Is there an identification section in the fsm somewhere? I looked at some axles online but was a little perplexed that there was so many transmission options.
I just assumed 89-94 3 cylinder was the same.
95-2001 3 cylinder same
and 4 cylinder 96-2001 same
also swift gt the same.
David95237
https://www.ebay.com/itm/Geo-Metro-5sp-Transmission-MV3-Bearing-Rebuild-Kit-FWD-Suzuki-Swift-1987-on/271147673582?hash=item3f21a927ee:g:8i0AAMXQC-tTFo7T&vxp=mtr
freegeo
smysmbrg
Jan 11 2018, 07:48 AM
I have not found any RPO codes in the FSM. Mostly it is described as final drive ratio's. You find the RPO codes show up mostly in the parts catalog. The Micro fiche I have for parts shows what all the codes are and gives a description of what they are. For a 91 xfi the trans code shows a MV2.
geogonfa
:gp My references show "MV2" also...
The MV2s were in the Sprints. When they went to Metros they upgraded them a bit and its an MV3.
freegeo
The following rpo codes are for metro trans.
Attached to this post:
Attachments: rpo_code_1.jpg (189.49 KB)
Attachments: rpo_code_2.jpg (165.26 KB)
Attachments: rpo_code_3.jpg (184.18 KB)
Edited by freegeo, Jan 12 2018, 12:27 AM.
