1994 Geo Metro LSI; Engine Code 51
Topic Started: Jan 22 2018, 04:19 PM (201 Views)
Jim R Caretaker
Is this thing on...
So my car cuts out intermittently at cruising speed, and idles a little rough.
The code is Faulty PCM.
Does that sound right?
geogonfa
Just my .02¢...
If it is a 1994 it would help to know if it has advanced emissions (black box, ISC, at the back of the TB) or standard emissions (IAC), and if it's a manual or automatic... :type
According to the FSM, ( http://geometroforum.com/topic/5044844/1/#new ) ,
code 51 = EGR System & REGT Sensor Circuit ...
Standard Emissions 6E2-A1 ENGINE COMPONENTS WIRING DIAGRAMS DIAGNOSTIC CHARTS
https://docs.google.com/file/d/0ByZnrvyffe1KV3NMSTh1SGZSSXM/edit
Advanced Emissions 6E2-A2 ENGINE COMPONENTS WIRING DIAGRAMS DIAGNOSTIC CHARTS UPGRADED EMISSIONS
https://docs.google.com/file/d/0ByZnrvyffe1KYjVBdjllUVBabDg/edit
Most likely the EGR passages are clogged...
Here is good reading: http://geometroforum.com/topic/678529/1/
Edited by geogonfa, Jan 22 2018, 05:13 PM.
MR1 Kingsbury
Exp. builder/rebuilder
I don't think the pcm has a self determined failure code.
Jim R Caretaker
Is this thing on...
MR1 Kingsbury
Jan 22 2018, 05:51 PM
Jim R Caretaker
Is this thing on...
I have a Haynes Manual. (24075)
Page 6-4. Step 8. Work like a charm. Next page it just reads "PCM faulty"
I'm confused, I didn't think the engine would even start with a faulty PCM.
MR1 Kingsbury
what code are you actually getting from the code reader/scanner?
pcm faulty is usually the last possibility after all other possibilities have been checked, corrected or dismissed.
Edited by MR1 Kingsbury, Jan 22 2018, 09:36 PM.
Jim R Caretaker
Is this thing on...
MR1 Kingsbury
Jan 22 2018, 09:34 PM
I get code 51. That's the on board diagnostic. Check engine light, a easy read.
Dystopiate666
Tree Banger
51 is egr, if the valve is sticking open it could cause you to stall, but usually code 51 means you have clogged egr passages, especially if they haven't been cleaned for the life of the vehicle.
Jim R Caretaker
Is this thing on...
Dystopiate666
Jan 22 2018, 10:19 PM
Will look into that, thanks
Jim R Caretaker
Is this thing on...
Dystopiate666
I see now... I was looking at the wrong list of codes. I'm gonna check that out. Thanks in advance.
Jim R Caretaker
Is this thing on...
geogonfa
Just my .02¢...
Thanks... I'm making sense of it now.
Jim R Caretaker
Is this thing on...
Thanks to everyone...
Jim R Caretaker
Jan 22 2018, 06:33 PM
Then you have nothing, you're winging it. That book covers three different body designs and six different engines running on three different control schemes. It is probably pretty useful for changing a water pump or doing brakes, but when it comes to genuine troubleshooting it might as well be a roll of toilet paper.
PCM (actually your 94 has an ECM) almost never goes bad, and if it did you'd be dead in the water. Intermittent problems are usually poor electrical connections or a failing fuel injector. Fuel injectors often stick closed while driving and then work pretty well for a while. The failing becomes more and more prevalent until they fail completely.
51 is clogged EGR, about half of all Metros have this and they're running fine.
Edited by Woodie, Jan 23 2018, 08:02 AM.
0 users reading this topic
