| AC 1996 1.0 L pull condensor; New condensor | |
| Tweet Topic Started: Feb 5 2018, 08:42 PM (256 Views) | |
| Iconn | Feb 5 2018, 08:42 PM Post #1 |
ICONN
What needs to be removed first to get the condenser out? I have the engine out. Can I get it out without messing up the hood latch? Thanks
| MR1 Kingsbury | Feb 5 2018, 09:01 PM Post #2 |
Exp. builder/rebuilder
have to get the frigerant out first... that's easy. then remove bolts and nuts attached to the condenser fan. I think one other bracket or bolt underneath and the connections to the compressor and the accumulator. |
| Stiffchezze | Feb 5 2018, 10:14 PM Post #3 |
Sir Metrologist
Pull the bumper first and after that it's gravy. The hood latch support has to come off too, but with the bumper off, it's just a couple of bolts. |
| Iconn | Feb 5 2018, 11:12 PM Post #4 |
ICONN
Have you ever had a hood latch that did no line up and now will not OPEN?! I tend to be paranoid about such things. thanks |
| Stiffchezze | Feb 5 2018, 11:22 PM Post #5 |
Sir Metrologist
If you leave the latch alone and just pull the support, the alignment does not change. However, a Metro hood latch is stupid easy to pop open if the pull wire doesn't work. |
| Iconn | Feb 5 2018, 11:39 PM Post #6 |
ICONN
Whew! I am glad you all are there. Thanks! |
| sphenicie | Feb 6 2018, 06:14 AM Post #7 |
if you do ever have to remove the latch, simply scribe around it before you loosen the bolts. |
| nickb803 | Feb 6 2018, 02:49 PM Post #8 |
NickB803
Freon then radiator assy. I'm about to do mine here in a month after I get the parts. |
7:53 PM Jul 10
