loose cable behind glove box; 1993 base
Topic Started: Feb 28 2018, 06:43 PM (275 Views)
ice
alex smiles
:type Hello all long time no write.
Well, it has been very cold in California and of course, the heater does not work :banghead
easy enough fix with a zip tie. but when I took a look-see behind the glove box and there is a black cable with A eye hook at the end of it just hanging there not connected to anything. It belongs to the sitting on the leaver with a picture of the car and arrow going around the car.I hope I described correctly.
I can post pics if need be. Thank you to all :thumb
MR1 Kingsbury
Exp. builder/rebuilder
that would be the recirculate or fresh air lever? That determines whether you are heating fresh air from outside or recirculating cabin air....
ice
alex smiles
hey king, long time no write, lol.
would you have a picture of what it hook into? Tight fit for a camera tho
Look between the metal of the side of the car and the fan box. The cable goes kinda deep in there. It is the furthest point to the right on the side of the black fan housing.
ice
alex smiles
:)))) hi ev :))) hows life? hope all is well .
I am trying to find a picture online. I will poke around too see if I can see the back of the fan housing
ice
Mar 1 2018, 02:00 AM
It's not on the back, it's on the right side. The two the cables go to the left side, and one goes t the right side. If you see how the two cables hook up to the left side, you will have a good idea how the one hooks up on the right side.
ice
alex smiles
hi to all, I see it on the side but were exactly does it hook into? there two moving parts there
You can look at how the two cables hook up on the left side, since you can see them clearly from the drivers floor area. The one on the right side hooks up the same way.
suzukitom
Tom
picture in link below:
http://geometroforum.com/single/?p=187053&t=2498912
Edited by suzukitom, Mar 2 2018, 05:23 PM.
ice
alex smiles
ahaa ... Thank you! a picture finally says it all.
Thank you to all.
thumbs up Tom on the thousand words.
