Any ideas where to find hub studs?; 10m×1.25 × 25mm
Topic Started: Mar 10 2018, 03:16 PM (195 Views)
Broons7388
So while doing breaks and rotors stripped one of the hub studs that attach to the rotors. Any ideas where to find a replacement? Autozone and such have not been helpful. Would some type of dealership have this stud? And unfortunately the junkyards don't have any metros around here
David95237
My Napa dealer shows having them.
compnut21
Geo Enthusiast
Dorman 610-336 is the listed front 12mm stud for our Geo, it should be available just about anywhere for a dollar or two per stud
Edited by compnut21, Mar 10 2018, 03:50 PM.
David95237
compnut21
Mar 10 2018, 03:46 PM
DORMAN 610336 is the listed front 12mm stud for our Geo, it should be available just about anywhere for a dollar or two
Original should be 10 mm.
compnut21
Geo Enthusiast
David95237
Mar 10 2018, 03:51 PM
compnut21
Whoops, didn't catch the 10mm bit. The 10mm studs (front or rear) are Dorman# 610-308
Hotrodray1
Over Educated parts guy
Napa number is 6412150 and it is a 10mm!
Broons7388
I appreciate the suggestions but i'm pretty sure you guys are giving me the reference to the hub studs that attach to the wheel w lug nuts which is also 10 mm. I need the bolt that goes from the hub to the rotor. It has a 14 mm hex head with a number 7 on the head.
Attached to this post:
Attachments: 20180310_151715_50_1_77_1_88_1_63.jpg (122.84 KB)
Edited by Broons7388, Mar 10 2018, 06:51 PM.
solerpower
Broons7388
Mar 10 2018, 06:49 PM
This is a month old, but why not answer it. You mean the bolts that go through the hub and bolt to the caliper? Off the top of my head these should be 10mm x 1.25. You can find suitable class of bolt at Ace Hardware, or most auto stores. I probably have about 50 of those bolt in buckets. You do want to measure the length and get a 10.9 or 12.9 metric class bolt.
Crvett69
Think he wants the ones that bolt the rotor to the hub, on older metro rotor sits inboard of hub and it has to be pressed apart and bolts removed to remove rotor. With the knurles will probably have to get from dealer, wrecking yard or bbowens
Edited by Crvett69, Apr 15 2018, 10:33 PM.
solerpower
Crvett69
Apr 15 2018, 10:21 PM
I think he should be able to find something close in the Dorman catalog. The knurl length does not need to be exact, but the diameter will need to be close. I have never seen the set up your describing.
Crvett69
comes on all normal 89-94 metros. red arrows
http://lh4.ggpht.com/_QZFIOYuA6xE/SfwGVXR2dxI/AAAAAAAAARQ/79o7iR8RzAA/s800/IMG_7937.JPG
Edited by Crvett69, Apr 16 2018, 11:44 AM.
