Fuel pump; Odd noise
Topic Started: Mar 11 2018, 03:20 PM (233 Views)
Az Mountaineer
az metro
When I turn the ignition my fuel pump makes a noise like a low foghorn. Runs fine though. Any input ?
freegeo
If it is the fuel pump making the noise you may want start looking for a new one now before it goes out.
When the key is first turned to the on position the pump runs for a few seconds. Does the noise stop at that time?
Edited by freegeo, Mar 11 2018, 04:07 PM.
Az Mountaineer
az metro
Yep
suzukitom
Tom
pumps get noisy before they fail. or if it has been sitting for a long time with old gas, it might get quieter again once it has been used for a while with fuel injector cleaner added .
the pump priming sound before start-up should be a quite faint hum. if it is loud, rough and audible that is not normal.
Edited by suzukitom, Mar 11 2018, 05:23 PM.
Az Mountaineer
az metro
It is driven daily, I will begin pricing them. Good thing I have AAA.
sser2
sser2
BTW, never ever install anything other than original Denso fuel pump. Replacing pump/sender unit is involving enough so you don't want to repeat it in a few month's time.
Az Mountaineer
az metro
Will do. Thanks.
