Second gear grind after bushing replacement
Topic Started: Mar 11 2018, 04:53 PM (247 Views)
CrystalWhite
Just replaced the shifter bushings on my GT due to sloppy and vague shifter. Since then I have gotten a slight but noticeable crunch going only into second on upshift.
The transmission had a hard life from previous owners, it was a bit notchy but never grindy like this. I used new replacement bushings from BBowens, replaced the 4 tan bushings and the 4 bushings connecting the shift rod to the transmission linkage. Could I have adjusted something causing this to grind or is this just new bushings causing this?
Shifter still has some issues with springy movement in neutral on the 1, 2 side of the H pattern. It doesn't spring back into place like the 4,5 R side. Any ideas?
Edited by CrystalWhite, Mar 11 2018, 04:54 PM.
suzukitom
Tom
lube applied to bushings during assembly? bolt/nuts/sleeves assembled correctly and not over tightened?
CrystalWhite
I greased the bushings, it may be possible I overtightened them, what is the proper torque settings?
suzukitom
Tom
i don't have the torwue values at hand but it isn't much, due to the metal sleeves keeping things from being crushed.
when you replaced the bushings did you put the shifter (part 10 i think) back in the same position in the transmission floorpan (4 bolts) usually there are yellow paint marks showing bolt positions
Attached to this post:
Attachments: s_l400__10_.jpg (23.27 KB)
Edited by suzukitom, Mar 11 2018, 07:29 PM.
CrystalWhite
I didnt touch that side of the shifter, the only bushings ive changed were 4 of the 18s, and both of the 24 and 25.
Dystopiate666
Tree Banger
perhaps the Actual steel links are bent....I bent some dropping a trans out once and it made the shift pattern kinda wonky and tight....probably would become more prevalent after you tighten things up.
Dystopiate666
Tree Banger
Start sourcing a new trans now, so youre not hard up when this one goes kaput.....I drove around without being able to downshift into second for about 70k miles ....then eventually I started getting blocked out of 1 as well....then in the final days/weeks it started popping out of fifth gear at high speeds......not to mention it screamed like banshee from day one till its final day.....
a crunch, grind, ribbit sound in only one gear is almost certainly the synchro on said gear
The only thing that has changed are external bushings. There is no adjustment for the syncros. With a sloppy shifter it might take just an extra half second or so to make the shift, giving the worn brass just a little bit longer to do its work. Best guess as a builder. It might be time to rebuild or replace this unit.
CrystalWhite
Thanks everyone, I'm going to relube the bolts, dial back the torque and replace the transmission fluid once I pop the blown out cv axle. Maybe that will be good enough.
What transmissions are cross compatible for these cars? Are transmissions from metros/sprints etc strong enough for at GT or would the best bet be rebuilding the existing one?
Dystopiate666
Tree Banger
I have good luck finding used trannies for mine....any manual trans from any metro will work, if its from a swift gt youll have to modify it (not likely this will be your scenario, they are rare). Sprint trans will not work in a metro I don't think.
Are you using syncromesh in your box?
suzukitom
Tom
i find it interesting that the grinding occurred only after the shifter bushing changes. your comment about the lack of left to center spring action from the 1-2 gate us interesting. after bushing changes on my car, this spring action was very positive on mine. I still think it is worthwhile for you to check the fore and aft adjustment on the shifter assembly in case it is slightly off due to the new bushings lengthening the travel of the shift rod.
